Wayne hat im anderen Forum angekuendigt, dass fuer den Kx3 eine neue Firmware im Betatest erprobt wird.
His Master's Voice:
* POWER OUT NOW 15 WATTS MAX, 80-20 M: On 80-20 meters, the PWR control can now be set as high as 15 W. Supply voltage must be over 12.8 V (during transmit) as indicated by the KX3’s voltage display (tap DISP, rotate VFO B). Specified max remains 12 W, and 15 W should only be used when necessary. The KX3 will automatically reduce power as required if current, SWR, or temperature is excessive, or if supply voltage is too low. If a band other than 80-20 m is selected, power output will be cut back to 12 W max. It must then be manually set above 12 W after switching to 80-20 m.
* PSK63 MODE ADDED: Tap DATA, rotate VFO B until PSK D is displayed, then use VFO A to select 31 or 63 baud. The default is PSK31.
* 4-METER POWER OUTPUT IMPROVED: Changed IF band-pass filter configuration to increase drive level on 4 meters. This should improve 4-meter power output in cases where it was marginal due to filter rolloff.
73 de Hajo
