Elecraft KX2 FM?
    zum Ausprobieren eines 2m 10m Transverters habe ich zuerst an FM und meinen selten (leider) genutzten KX2 gedacht.
    Dort habe ich aber nur AM gefunden.
    Auf der Elecraft-Seite (USA) stand dann aber bei den modes auch FM!
    Weiß jemand etwas näheres übe Neuerungen, updates o.ä.?
    vy 73, Hans-Gerd (DH1YBD)
    vy 73, DH1YBD
    Hans-Gerd
  • [Elecraft] FM mode on KX2 ready to test on 10 meters and with transverters
    Wayne Burdick Sun, 03 Dec 2017 14:10:12 -0800
    Code
    I have field-test firmware ready for those interested in trying FM mode on the KX2. On 10 meters, FM is useful for both repeaters and simplex FM QRP DXing. For external transverter use, there are programmable band displays (up to 7), as well as a keying output.
    Code
    The implementation includes PL tone encode (TX), programmable repeater offsets, and control of both overall deviation and PL tone deviation. FM mode can be turned off in the menu if it’s not needed.
    If you’d like to test the new release (rev. 2.87), let me know.
    Wayne
    N6KR
    KX2 MCU 2.89 / DSP 1.52, 12-10-2017
    * ADDED FM MODE: FM mode can be used on any band, but it is intended for use with 10-meter repeaters (or 10 meter FM simplex DXing) as well as with external transverters. (For transverter band display setup instructions, see owner’s manual.) FM is considered experimental on the KX2 pending field test results.
    FM Instructions:
    - FM mode can be enabled or disabled using MENU:FM MODE
    - To adjust squelch, tap FIL, then rotate the AF GAIN knob
    - To select +/-/SIMPLEX repeater offset, hold SPLIT
    - Set up repeater splits per-band/per-memory using MENU:RPT OFS
    - Adjust FM deviation using MENU:FM DEV
    - To adjust PL tone deviation, locate MENU:FM DEV, then tap ‘1’ (PRE)
    - To select PL tone, use MENU:FM TONE. Tap ‘1’ to turn tone on/off.
    Note: 1750 Hz tone not usable at this time.
    Quelle:bfwnotes.txt
    Ich besitze selber keinen KX2 sondern habe einfach mal im Internet gesucht.
    Eventuell musst du also die Firmware aktualisieren, wenn deine Firmware rev kleiner als 2.87 ist.
    viel Glück
    Walter, DL6HAK
  • Vielen Dank Walter, hat geklappt, FM läuft, auch über den Transverter.
    Firmware war schon aktuell genug.
    Meine Internetsuche war nicht so erfolgreich :wacko: ... !
    Dann müssten nur die gedruckten Anleitungen auch upgedatet werden.
    Hans-Gerd, DH1YBD
    vy 73, DH1YBD
    Hans-Gerd
