Folks!
Mir ist da ein Hinweis zugetragen worden den ich überaus interessant finde. Ein Gerät das 2m/70cm analog und Digital macht als auch ein Android Mobiltelefon ist. Die Jungs wollen knapp unter $1000 dafür. Das wird die Menge wohl drastisch beschränken. Von den Specks her meine ich ist das eine eierlegende Wollmilchsau. Zusätzlich gibt's eine WLAN Kommunikation das ist eigentlich die Ursprungsidee dieses Anbieters. Dieses Gerät geht aber weit darüber hinaus.
https://rfinder.shop/product/rfinde…_eid=5c9fc4a121
Zitat der Produktseite:
ZitatThe RFinder B1 is the most advanced Dual Band (VHF/UHF) DMR Transceiver combined with an embedded powerful smartphone. It delivers up to 4 Watt of RF Power out of its very robust case.
Running Android, you can install all the available Play Store apps. This means that you can install Zello, Team Speak, EchoLink and many others and use the built-in PTT button to key the transmission on such apps. Can you imagine that? If you don’t reach an EchoLink node, just use your RFinder 3G, 4G or even WiFi, and you are connected. Never miss a QSO again just because there isn’t a nearby repeater. And because the RFinder has an updated database of worldwide repeaters, EchoLink nodes and DMR talk groups, you never have to memorize anything. You just search the station or repeater you want to connect, and the RFinder will change all the settings for you, either using DMR or conventional analogue FM. The RFinder is so advanced that will allow you to see on a map all the available DMR/EchoLink/Conventional repeaters nearby. Just click on your selected station, and your radio settings are changed: RX and TX frequency, Tones, offsets, splits, color codes. Everything! Welcome to the first Click & Talk transceiver. If this is not phenomenal what is it then?
enjoy!
OE1IAH
