SLUSB Soundcard Error unter WIN10 nach Update auf 1807
  • Gerade auf der Tigertronics Seite gefunden:
    "Sound Card Error" after Windows 10
    update Version 1803
    The most recent Windows 10 update to Version
    1803, is shutting off microphone access for some users due an incorrect privacy
    setting. This results in an error message when starting the communication
    program (Fldigi, WSJT-X, Digipan, etc.). If you have just updated your
    Windows 10 OS with update 1803 and are experiencing this error, then follow the
    steps below to resolve it. Please note that this solution applies to
    update 1803 only. To the best of our knowledge, prior updates have not
    caused this problem. If you have experienced a different problem after a
    Windows 10 update, then we would suggest that you double-check that your sound
    card settings in Windows and the communication program are correct (these
    settings can change after a Windows update).
    Special thanks to Richard, KE6SHL, for providing
    us with this information!
    1 - Close any communication programs that may be
    running.
    2 - In Windows, go to All settings, then
    Privacy.
    3 - Scroll down to App Permissions, Microphone.
    4 - On the right side panel, select/enable "Allow access to the microphone
    on this device".
    5 - Microphone access for this device should now be ON. If not, then
    click Change and switch it to ON.
    Note that you can apparently have the switch under "Allow apps to access
    your microphone" off and the SignaLink USB will still work.
  • Danke für Deinen Post ,das hat meinen WSJTX wider in die Spur gebracht.
    72 de dh1bay
    72 de DH1BAY Die meisten Probleme der Menschheit liegen zwischen den Ohren(HST).
