seit einiger Zeit wird auf Ebay dieser Monband QRP TRX für 40m angeboten.
Gibt es hier schon Erfahrungsberichte ?
eBay-Artikelnummer:
181813278668
EFE-40 SSB QRP 7MHz
EFE-40 SSB QRP 7MHz (40 meter) monoband kit is a NE602-based superheterodyne HF transceiver with DDS VFO. This kit only for 40 meter HAM band.It is driven by a stable DDS VFO and has the following features;
Fully Assembled and tested
Input voltage 10-14V DC
Current consumption RX 30~50mA, TX 500~950mA
7.000 - 7.300 MHz ham band
Output RF power 4-5 watts
Second harmonic output -45dB
Other spurious signals -40dB or better
RX+TX crystals filters 4 pole 2.4 kHz
0-10MHz DDS VFO. Stable frequency, no more drift!
Simple to operate using a single rotary encoder control with press button switch
Graphical S-meter
Battery voltage indicator (DC Voltmeter)
Dimensions: Rf board 120x95mm --- Vfo board 115x55mm
RIT function
Besten Dank
Tom DL2TS
