Hallo zusammen,
im Folgenden eine Ankündigung der AMSAT für das kommende Wochenende. Das sollte auch nur zum reinhören interessant sein.
Viel Spaß
Gruß Holger
SB SAT @ AMSAT $ANS-101.06
Arecibo on 432 MHz Moon Bounce
AMSAT News Service Bulletin 101.06
From AMSAT HQ SILVER SPRING, MD.
April 11, 2010
To All RADIO AMATEURS
BID: $ANS-101.06
The Arecibo Observatory Amateur Radio Club will be putting the
1000-foot radio telescope on the air for 432 MHz EME from April 16-18.
It can be heard with a small hand-held yagi pointed at the moon
The scheduled times of operation are:
April 16: 1645 - 1930 UTC
April 17: 1740 - 2020 UTC
April 18: 1840 - 2125 UTC
Callsign: KP4AO
Tx Frequency: 432.045 MHz
Rx Frequency: 432.050 to 432.060+
Tx power: 400 W
Antenna gain: 60 dBi
System noise temp: 120 K (cold sky)
System noise temp: 330 K (when pointed at moon)
KP4AO can be heard with a small hand-held yagi pointed at the moon and a
good receiver. A 15 dBi antenna and 100 W will be enough to work us on
CW.
Operators at KP4AO will do their best to work as many stations as
possible. Each session will start with a brief announcement and CQ in
SSB. SSB QSOs may continue for 30 minutes to an hour, if the QSO rate
remains high.
The mode will be shifted to CW as soon as it is judged that higher QSO
rates would result.
We will listen for calls at frequencies 5-15 kHz higher than our own,
and even higher if QRM warrants. Callers who s-p-r-e-a-d o-u-t are more
likely to be copied.
If you've already worked us in any mode, please do not call again --
give others a chance.
If we call "CQ QRP", we will listen for stations running 100 W or less
to a single yagi. Please do not answer such a CQ if you are running more
power or have a larger antenna.
On April 18, if we reach a condition where most calling stations have
been worked, and we judge that operating in the digital mode JT65B would
produce a higher QSO rate, we will switch to JT65B.
Note that any of these planned operating strategies may be changed as
circumstances dictate.
We are extremely fortunate to have been granted access to the world's
largest radio telescope for this amateur radio good-will event. We look
forward to working as many stations as possible in the alloted time!
[ANS thanks John, KB1MGI, for the above information]
/EX
