THE 1 WATT GAME 2026 - PART 2: 17.10.2026, 0900-1200UTC, 14.060 +/-10kc
  • Weitergeleitet aus der EU-QRP-Foxhunt-Community,
    auf eine Übersetzung verzichte ich, die Daten sind selbsterklärend und im Zweifel helfen Tante Google & Co.
    THE 1 WATT GAME 2025 - PART2
    I. OBJECTIVE: A short QRPP CW game on the 20 meterband. All radio amateurs and SWLs are cordially invited.
    II. DATE: Saturday 11 October 2025 from 0900 to 1200 UTC.
    III. BAND: 20 meter band only. 14.060 MHz +- 10 kHz.
    IV. POWER: maximum 1 watt.
    V. OPERATION: Only CW (A1A).
    1. CALL: CQ 1W
    2. EXCHANGE: RST / POWER / LOCATOR
    ie. 559/1w/ JO21LA. Additional info like power, RTX, antenna,... is welcome.
    VI. SCORING:
    First calculate the distance of each QSO.
    QSO points = distance divided by the power of the other station (in watts).
    Power less than 1 watt is equal to 1 watt in the points calculation.
    Eg. your counter station is 2000 km away and uses 5 watt. Then the point count for this qso is: 2000/5 = 400 points.
    Eg. your counter station is 3000 km away and uses 1 watt. Then the point count for this qso is: 3000/1 = 3000 points.
    Eg. your counter station is 3000 km away and uses 300 milliwatt. Then the point count for this qso is: 3000/0,3 = 10000 points.
    TOTAL SCORE: Sum of all QSO points.
    The use of simple antennas is highly recommended.
    VII. LOG SUBMISSION:
    Email your score to on6kz@hotmail.com ( ! NEW EMAIL ADDRESS ! )
    Add the text: Me, (your call) , I declare that I managed a total of XXX QSOs, my total result is XXX points.
    Please add your best DX (call and locator) station-info: locator, power, RTX, antenna. Pictures of your set-up are appreciated.
    VIII. GAME REFEREE: Peter Kempenaers (ON6KZ/OO7Z). The Game Referee has the right to request full log in case of any doubt.
    IX. LOG DEADLINE: 25 October 2025.
    X: Nominees: award for the winner, the best DX, funiest location (if outdoor), original home brew, lowest power.
  • >Power less than 1 watt is equal to 1 watt in the points calculation.
    Vielleicht ist ja mein Englisch ein bisschen eingerostet, aber...heißt das, dass meine eigene Leistung immer mit 1Watt eingeht,
    während die der Gegenstation auch kleiner sein kann und dann mehr Punkte ergibt?
    Peter
  • Wenn man drüber nachdenkt, macht es sogar Sinn.
    Ich kann meine eigene Punktzahl nicht dadurch erhöhen, dass ich eine extrem niedrige Leistung z.B. 10mW benutze.
    Falls ich dann tatsächlich damit eine Verbindung schaffe, bekommt das Gegenüber den Bonus-Faktor.
    Zu Recht, senden mit 10mW ist einfach, das Signal zu lesen eher nicht.
    Peter
  • Was denn jetzt, max. 1 Watt und warum dann auf einmal 5 Watt?
    ... und ich dachte dass nur mir das rätselhaft vorkommt. Ist unglücklich formuliert, denn es gibt ja die Bonuspunktberechnungen. Basis ist 1 Watt.
  • In der Tat, unglücklich formuliert:
    Sollte besser heißen: 'If your(!) power is less than....'
    Ich denke Haiko's Problem ist so zu verstehen, dass man auch Stationen außerhalb des Wettbewerbs arbeiten und dafür Punkte bekommen kann,
    so man ihnen denn Locator/Power entlocken kann.
    Peter
  • dass man auch Stationen außerhalb des Wettbewerbs arbeiten und dafür Punkte bekommen kann,
    Das ergibt einen Sinn.
  • Aus aktuellem Anlass hole ich das Thema nochmal vor: morgen, 11.10.2025, 0900-1200UTC, 14060 +/-10kHz, CQ 1W, 2. EXCHANGE: RST / POWER / LOCATOR, ... siehe #1 ;)
  • Find ich gut, interessant und kurzweilig.
    Die Beteiligung war da. Zeitweise bis zu 20 Stationen zeitgleich im Wasserfall zu sehen.
  • Ich hatte leider nur sehr wenig Zeit, konnte aber einige Stationen erreichen. Macht mächtig Spass mit nur einem Watt, in kürzester Zeit, mehrere europäische Länder zu arbeiten.
    Stn: K1/ 1W und 2*7m Doublet, conds ufb.
    Da werde ich bestimmt Wiederholungstäter:).
    73 de Uli, DL8SBX
    DL8SBX
  • Das war ein großer Spaß und die Bandbedingungen haben prima mitgespielt.
    Obwohl ich nur die Hälfte der Zeit nutzen konnte (über Mittag kommt man aus der einen oder anderen Familienverpflichtung einfach nicht raus), sind mir 15 QSOs geglückt, 10 davon 2x VLP, die hops lagen bei mir alle zwischen knapp 700 bis 1500km.
    Für die Teilnahme habe ich den 7300 auf 1% ~ 1W reduziert, Antenne unverändert meine triple leg nach DK7ZB.
    Ich freue mich auf Teil lll...
  • Morgen 0900-1200UTC (Achtung, verschlaft die Zeitumstellung nicht ;)) ist es wieder soweit!
    Regeln unverändert, nur die Logs gehen jetzt an on6kz@hotmail.com
  • dm4ea September 7, 2026 at 3:55 PM
    Changed the title of the thread from “THE 1 WATT GAME 2025 - PART2: 11.10.2025, 0900-1200UTC, 14.060 +/-10kc” to “THE 1 WATT GAME 2026 - PART 2: 17.10.2026, 0900-1200UTC, 14.060 +/-10kc”.
  • Die nächste Auflage steht vor der Tür,
    es bleibt aber noch genügend Zeit, den alten SST-20 abzustauben oder notfalls noch einen kleinen TX zusammenzulöten oder über eine leichte, effiziente Antenne nachzudenken und die bei der Gelegenheit auch einmal auszuprobieren!
  • Aus aktuellem Anlass hole ich das Thema nochmal hervor, morgen 0900-1200UTC ist es wieder soweit, 14060 +/- 10kHz
    Ich werde mit dem DL-Clubcall des GQRP unterwegs sein, als DL0VLP passt das auch prima zum Anlass ;)
  • Hoffentlich geht dieses 1 W Festival für die leisen Töne nicht im Gebrodel der Power Stationen unter. Denn an diesem Wochenende summieren sich mal wieder Contest und ähnliche Aktivitäten.
    Gleichzeit findet auch das JOTA (Jamboree on the air) statt. Anruf-Frequenzen 7190 kHz, 14290 kHz, 21360 kHz und 28390 kHz.
    "Be patient and encouraging - it might be their first QSO"
    Und von Samstag bis Sonntag der Worked-all-Germany Contest. Mal sehen ob es diesmal wieder Fälle von rücksichtslosen "Breitbandstationen" zu bemängeln gibt.
    Edited 5 times, last by DL4ZAO (October 16, 2026 at 2:31 PM).
  • Die Condx waren noch etwas 'nervös', SFI 131, K 1, A17, ich habe stellenweise tiefes QSB beobachtet, über längere Phasen war es aber auch recht stabil.
    Conteststörungen gab es praktisch keine, ich hatte zwischendurch ein entspanntes QSO mit Max an der Scout-Stn SJ0AT, CW-Newbie mit 60W an 4el, die anderen YOTAs waren vmtl alle in SSB oder Digimodes unterwegs.
    Aktivität war ok, auf 20m hört man halt die anderen Teilnehmer in der Toten Zone nicht und via Bodenwelle ist mit 1W auch nicht viel zu machen ;)
    Am Ende wurden es 21 QSOs, 18 davon 2xVLP, ODX 2.611km, durchschnittliche Distanz/ QSO 1.124km, damit bin ich sehr zufrieden.
    Jetzt freue ich mich auf die kommende Session im Frühjahr '27, dann vielleicht mal mit einer temporären Monobandantenne, habe da entweder ein DK7ZB-Oblong oder eine VP2E im Auge...
    war auch wieder beim 1-Watt-Game dabei und es hat auch diesmal viel Freude bereitet. Es sind zwar nur 10 QSOs zusammen gekommen und das ODX lag bei 1401 km (Durchschnitt 928,3 km), dabei waren allerdings auch "nur" 500mW am Start. Freue mich schon aufs nächste mal.
    72 Falco DL2LQC
