Hi Gang,
I am finishing my second band module for my SIERRA (WILDERNESS RADIO Version Rev. D). Bought 1997 - Build 2015/6.
Right now I am aligning the RX stage. I am using this task to work on my SIERRA (here the ABX), too.
Referring to a post and a document of Richard K3KRW (attached to this post), I needed to adjust the ABX function in my SIERRA, too.
As I don’t have the same software Richard used, I thought I might use what I have. An old version of Spectrogram. To my opinion Spectrogram V. 5.1.7 is doing quite the same as the digital modes software DM-780 Richard used.
Spectrogram V. 5.1.7 is also used by Hams aligning their K2s for their SSB and CW reception.
So why not using it for the ABX topic on the SIERRA.
I now have some questions on adjusting the BFO / ABX on the SIERRA using a spectrographic software connected to the audio output.
-> TEST SETUP:
Connected a signal generator (ELECRAFT XG3) on the desired frequency to the SIERRA input.
Tuned the SIERRA to the same frequency.
Using the PC software Spectrogram V. 5.1.7 bandwidth settings from 0 - 3000 Hz.
Audio 3/4 open.
On the PC I can now see the maximum of the rx signal at about 600 Hz (varies with RX frequency). When I turn the VFO up or down this rx signal moves up or down on the bandwidth scale.
In parallel I have an audio speaker connected.
The AGC is checked and set to about 1/2 position.
C1 and C2 on the band module are set to maximum reception.
This is visible in Spectrogram V. 5.1.7
The BFO is set to 600hz with its maximum, too.
-> PROBLEM:
The ABX is set to wide (0% = max))
Everything is perfect, max. RX signal on Spectrogram V. 5.1.7 and in the speaker.
ABX set to 1/2 (50% of max):
The RX signal strength starts to drop.
ABX set to narrow (100% of max)
ABX to minimum bandwidth, the incoming RX signal (using the XG3 set to -1uV = S1) totally disappears.
I thought when the BFO is adjusted right there will be no loss of the rx signal.
I still think I did something wrong but I have no idea where I took the wrong turn…. ![]()
How can I manage that the rx signal keeps up, like Richards, even with the ABX fully turned to 100% (narrow bandwidth)?
Any thoughts….
Thanks
72/3 de VY1QRP / DM5TU - sTef
